Integration between OAM/OID and Jira/Confluence/Bitbucket
Samir Kabiraj December 3, 2019
We are looking for options to integrate Jira/Confluence/Bitbucet server version to Oracle Managed Cloud Service (OMCS) OAM/OID.
Is that possible, even using some plugins?
Please point me  to any available documentation etc.
Nic Brough -Adaptavist-
December 7, 2019
Does the OMCS operating system support running Java?  If so, you can run the Atlassian servers on it.  You'll need to log in and perform the installs as per standard Atlassian docs.
Samir Kabiraj December 9, 2019
Actually, the problem is to integrate Jira, Confluence and Bitbucet server (on OMCS) to Oracle Access Management (OAM) and Oracle Internet Directory (OID). Did anyone have an integration between Atlassian tools and OAM/OID? If yes, how?
December 25, 2019
I have not found any way to use OAM/OID as a user directory for the Atlassian suite.
