Is Easy Links compatible with Jira data center?
Fernando Tonon
May 5, 2021
I use Jira data center v.8.5.3 and I'm configuring it for high availability.
In the marketplace we only have download option for Jira Server.
Has anyone had any problems to use this plugin with multiple nodes?
Thanks in advance.
Fernando
Brant Schroeder
@Fernando Tonon - Easy links, https://marketplace.atlassian.com/apps/1216498/easy-links-for-jira?hosting=server&tab=overview, is only validated to work with Server.  If it is only validated on server it may work on DC but you could run into issues.  I would suggest testing it on a test instance or even better reaching out to the vendor by emailing them here: https://marketplace.atlassian.com/apps/1216498/easy-links-for-jira?hosting=server&tab=support
Fernando Tonon
May 5, 2021
Hi Brant,
Thanks for the answer.
In my tests, using  Easy links in Jira DC, I had no problems with 2 nodes.
Anyway, I sent an email to the developer.
I asked him about reservations about using Jira DC with multiple no.des, and if he plans to develop a paid version compatible with Jira Data Center.  I'm waiting for the answer.
Thanks for your help!
Fernando
Like # people like this
Chris Annal
@Fernando Tonon Thanks for sharing this. We are also going from Jira Server to Jira Data Center. Please post any response or updates you may have on this topic. I appreciate it!
MOEX
February 1, 2022
Hello Fernando,
any news from Easy Links developer about Jira DC support?
regards.
