It was recently announced that there is an upgrade to Jira Core called Jira Work Management, which I gather includes new team management tools like calendars and other things.
Is this new functionality including in my Jira Software Premium subscription, much as the Jira Core was included in Jira Software in the past?
To simply put it "Yes". Jira core is the fundamental building block for the entire Jira suite and JWM is definitely included as a bundle when you get Jira software. However please do not add JWM as an application in your product as that will bill you separately for JWM.
Hi Shaun,
Yes, it is included. :-)
Cool. So are the Work Management functions like Calendar, etc. only in non-software projects?
Is there a place where I can see ALL the new features in action, preferably on video?
Yes, they are only on the Business type projects right now.
The best thing is to create a test project and play with it. :-)
Here's the marketing stuff - not sure there are any videos out there yet:
Also just to clarify on this, so even if you have Standard JIRA licenses JWM is included?
You don't need to purchase both JIRA and JWM licenses separately?
This is not always so cut and dry. I am assisting a team with their Server to Cloud migration and was required by the JCMA to add JWM. Now the customer is being charged separately for JWM, and Atlassian denies our claim that JWM should not be charged when JSM and JSW are licensed.
It's being worked out, but it is not as simple as it seems.
It is actually that simple.
JWM is always installed, it's actually the "core" of Jira - Software and Service Management are not independent applications, they run on top of JWM.
The three applications are licenced separately - you can do things like 3 JSM agents, 25 JWM users and 50 Software users.
Assuming your people are all in different groups and only take one licence each, then the JWM users won't be able to use Software boards, or act in Support projects. The Software users won't be able to act in Support projects, and the Agents won't be able to use Software boards.
Both Agents and Software users will be able to use JWM projects, without being added as JWM users.
If you're being billed for JWM and Software users and they're the same people, then you should be able to simple remove them from the JWM permissions, and only be billed for the Software users.
@Nic Brough -Adaptavist- respectfully, it really was and is not that simple.
Yes, you're right that JWM is always installed.
Tell that to the JCMA when it wants to take its ball and go home. Maybe that's fixed now? Back then it was not. I was unable to move forward with a migration without explicitly adding a JWM product to the site - and Standard - free was also not accepted by the JCMA. This made for a nightmare scenario for billing and for the migration overall.
JCMA is a different "kettle of fish", and it makes all sorts of mistakes. We regularly get requests for "trial" or "extension" licences which are actually all about using JCMA to do a Cloud migration, and our consultants are often the people asking for them.
Migration (with or without JCMA) is not as simple as Atlassian would like you to believe.
But using one of the Jira applications is that simple, and after migration, you can drop your uneeded licences.
Au contraire :)
That, too, was not possible, I believe, due to it being an annual license.
Trust me when I say this was weeks-months of migraines :)
Can anyone confirm that JWM is still included when using JSW?
