Is it possible to SumUp Issues Remaining estimates on the Search result screen in Jira Cloud?
Dmitry Mironov
February 20, 2022
Hi, I used SumUp addon with Jira Server , and this addon was able to summarize original and remaining estimates right on the Issue search result screen (like on a picture).
Now I use Jira Cloud, i've installed SumUp addon, but now it sumup estimates only in Dashboards of Filter's results. Is there a way to sumup issues estimates on the search result screen?
Alex Koxaras -Relational-
Hi @Dmitry Mironov and welcome to the community!
I'm not familiar with the specific app. However keep in mind that apps on server function very differently than on a cloud environment. With that said, either you wait for someone who used the app (or have time to install the app on his instance and try it himself), or you turn to the vendor's support. Most likely on the latter you will find a proper answer.
Dmitry Mironov
February 21, 2022
Hi @Alex Koxaras -Relational- , thanks for your reply and greetings!
I've read app's documentations and in Cloud version, developers declare only dashboard summarizing, so i can't blame the app. Looks like they are limited it's abilities in Cloud Version. Maybe someone from the community faced same issue and has same need in the summarizing estimates on the search results screen and found solution with other app or a built-in option. So i will wait and will keep trying to find it out by myself.
