Is it possible to add a manual value in project picker field ?
Tanu Ranjan Bharadwaj April 26, 2021
Hello Team,
The scenario is that we want a value "Others" in project picker field.
Is it possible to add a manual value in project picker field through scripts or through any other medium ?
Thanks in advance.
Best Regards,
Brant Schroeder
@Tanu Ranjan Bharadwaj
Since the project picker field selection is tied to a project adding an additional option would most likely cause an error when it is saved.  You might be able to add other through a script but I think it would break when you go to save it.
Tanu Ranjan Bharadwaj April 29, 2021
Ok Brant. Thank you for your reply.
Best Regards,
