×We are currently creating a new project in Jira, and in regards to the associated workflow - for each status, we would like some kind of a "pop-up" box to appear, when you move the mouse over each status. This simply to explain our colleagues which tasks to be effected in each status type, before changing to next status type.
It could also be, a text box added below the workflow with help text for each workflow status.
Are the above mentioned suggestions possible? If not - do you have any other suggestions?
Carina
@Mark Segall I'm also new here, and trying to do the same as Carina. I am working on Cloud. Where do I configure the Transition Screen "Pop Up" - I cannot seem to find it in Project Settings.
Thanks in advance!
More specifically, what do you mean by 'create a special transition screen and assign that screen to each of the desired transitions in the workflow'
Hi @Donika Pacolli and welcome to the community!
Some prerequisites for this:
Once you've confirmed that, you'll take these steps:
Hi again,
Thank you for your answer. I followed your guide and made it work - the only thing I had to change was to create the field as Message Custom Field (for edit). That was the only way it would appear on the 'resolve' screen, which was the status I wanted the info-box to appear on.
Best
Donika
Ahh, you're right. The view version is just for view screens. Good catch.
@Donika Pacolli Message Custom Field (for edit or View) not working in Jira Service Management, it was earlier working when i was using Jira Service Desk, is there any way we can add a text message to pop-up transition screens?
Hi @Carina Kærvang and welcome to the community!
Are you on Jira DC/Server or cloud?
If you're on cloud, you have a couple options:
1. Static Message Custom Field on the issue screen
The Message Custom Field is a field where you set static text. You can add it to the issue screen and as users get more savvy with the workflow, they can either pin more important fields above it or you can eventually just hide it from the screen.
2. Transition Screen "Pop Up"
Similar to above, you'd create a Message Custom Field, but instead of adding it to the issue screen, you'd create a special transition screen and assign that screen to each of the desired transitions in the workflow.
I highly recommend not going this route because your more savvy users will get frustrated quickly at having an extra click every time they want to transition an issue.
Hi Mark
Thanks, and thank you for your reply.
We are on server 😬. Are there any options then?
Br
Carina
It looks like this is possible in server/DC as well:
