Is it possible to add validation when changing an issue type in Jira?
Asier Vadillo
Hi everyone,
We have a specific scenario in Jira Cloud:
  • We work with Stories and Bugs.
  • Bugs have the Severity field, which is mandatory when creating a bug.
  • Sometimes, a Story is determined to actually be a Bug, and its issue type is changed via a transition or editing the issue.
The problem is that when a Story is changed to a Bug, the issue becomes a Bug but the Severity field is not prompted, so it can remain empty even though it’s mandatory.
My question is:
  • Is there a way to add validation when changing the issue type so that the user must fill in the required fields of the new type?
Thanks in advance!
Chitra Nagdeo
August 27, 2025
Hey @Asier Vadillo ,
Jira’s required field settings in Field Configuration only enforce mandatory fields on the Create and Edit screens—not when changing issue type. So, if you change a Story to a Bug, the Severity field (even if required for Bugs) may remain empty unless the user edits it manually. The most reliable way to enforce required fields when changing issue type is to use a workflow validator on the transition that changes the issue type.
How to do it:
  • Use Jira Workflow
  • Add a "Field Required" validator to the transition, and set a condition so it only applies when the issue type is Bug.
  • This will block the transition unless the Severity field is populated.
Native Jira Limitation: Jira Cloud does not provide a way to enforce required fields specifically on issue type change without a workflow validation. Required fields are only enforced on Create/Edit screens and not on the issue type change itself. Ensure the Severity field is on all relevant screens and required in the field configuration.
I hope this should help you achieve the necessary configuration. Have a good day!
Regards
Chitra Nagdeo
Asier Vadillo
Hi @Chitra Nagdeo ,
I understand but I am a bit lost,
When you mention a transition, which one do you mean exactly? From what i know, workflow transitions happen between statuses, but in this case only the issue type is changing. Since the status does not change, I do not see how a workflow transition would be triggered. Am I missing something?
Thanks!
Chitra Nagdeo
August 27, 2025
Hey @Asier Vadillo
I understand, you need to separate the workflow between Story and Bug, now using the "Move" option change the work type and define the status for Bug. Check "All" and for that specific transition add the validator step.
If the above is not working then we have to make the Severity field as Required in both Story and Bug work type to achieve this requirement.
Regards
Chitra
Asier Vadillo
Hey @Chitra Nagdeo ,
The stories does not have said field, that's the core of the problem. I will see if the all transitions work.
Thnaks!
Like Chitra Nagdeo likes this
