Hi @RG ,
Please check your field configuration for field Comment. Go to Jira administration area and click on the Issues.
Then choose Field configuration in the left column. Look for Comment field type in the list. If the default text renderer is set (like below) you won't be able to format any comments.
Click on Renderers on the right and switch to "Wiki Style Renderer". Then click on Update.
I hope it will help you.
Regards
Valdes
