Is it possible to change an issue status using Script runner Cloud
Mohammed-Amine Rouh January 14, 2019
I am trying to change an issue Status (To Do, In Progress or Done), using the following simple method
// Code 1
def result = put("/rest/api/2/issue/${parentEpicKey}")
.header('Content-Type', 'application/json')
.body([
fields: [
status: "[self:https://domain.com.atlassian.net/rest/api/2/status/3, description:This issue is being actively worked on at the moment by the assignee., iconUrl:https://domain.com.atlassian.net/images/icons/statuses/inprogress.png, name:In Progress, id:3, statusCategory:[self:https://domain.com.atlassian.net/rest/api/2/statuscategory/4, id:4, key:indeterminate, colorName:yellow, name:In Progress]]"
.asString()
I get the following error :
{"errorMessages":[],"errors":{"Status":"Field 'Status' cannot be set. It is not on the appropriate screen, or unknown."}}
       |                    false
I have already extracted the value of Status for tickets with this :
//Code 2
def fields = get("/rest/api/2/field")
.asObject(List)
.body
.findAll { (it as Map) } as List<Map>
def statusField = fields.find { it.name == 'Status' }
logger.info("statusField : ${statusField}")
which prints the values I am trying to assign to Status in Code 1.
Does anyone have any idea please on what I am missing ?
Thank you
5 votes
Nir Haimov
Yes you can, use:
POST /rest/api/3/issue/{issueIdOrKey}/transitions
in your body you need to send:
"transition": {
    "id": "5"
Read this:
https://developer.atlassian.com/cloud/jira/platform/rest/v3/?utm_source=%2Fcloud%2Fjira%2Fplatform%2Frest&utm_medium=302#api-api-3-issue-issueIdOrKey-transitions-post
Nic Brough -Adaptavist-
January 14, 2019
Status is not a field you can just edit, it is an indication of where an issue is in the process.  To change it, you must use a transition to move the issue through it.
Like HUI LI likes this
Thank you I wasn't aware of that, however the transition is Empty
// Get available transitions
def transitions = get("/rest/api/3/issue/${parentEpicKey}/transitions")
.asObject(Map)
.body
.issues as List<Map>
logger.info("transitions: ${transitions}") // Returns Null
// To find the Transition ID, is there any way to not start guessing
// Error "Transition id '2' is not valid for this issue
def result2 = post("/rest/api/3/issue/${parentEpicKey}/transitions")
.body([
transition: [
"id": "3"
.asString()
Thank you, I wasn't aware of Transitions however the value seems to be empty to know which ID to send.
// Returns Null
.asObject(Map)
.body
// Tried few IDs from the status or just as a guess nothing seems to be working
//"Transition id '3' is not valid for this issue
.body([
transition: [
"id": "3"
.asString()
January 14, 2019
You need to use a transition that exists and your user has permission to use.  This depends on what status the issue is currently in and what your workflow says.
Amine-Rouh
Worked like a charm, Thank you @Nir Haimov and @Nic Brough -Adaptavist- for the support, Appreciated
Gustavo De Marco August 20, 2019
hey can u help me u do u do that ?
Frank Sessler
@Mohammed-Amine Rouh
I suppose you have found the answer, as this thread is more than 3 years old. Anyway for others (like me): you may find the transition ID in the workflow configuration, text mode.
