I'm using the X-ray plugin, I'd like to create a quick filter to show only issues if they don't have a test issue linked against it, that way I can easily see whether there are still tickets I need to make test cases for.
EDIT - My answer doesn't take into account X-Ray, I am not sure if that changes anything for you or not.
https://support.atlassian.com/jira-software-cloud/docs/advanced-search-reference-jql-functions/
You can find the syntax for LinkedIssues on this page. It's a case-sensitive type of link syntax.
For example:
issue in linkedIssues(ABC-123,"is duplicated by")
There is a limitation here, so it may not work out the way you want. You'll need to include the issueID in the query, which probably means this won't work for you.
Hey Alex, so how did you get it to work? I would appreciate the insight, because I have a very similar case, but the linkedIssue function is not helpful.
