I want to create a post function for Incident issue type only, to send an email notification to the emergency team, is that possible without affecting the other issue types?
I don't want to notify the emergency type for tasks and stories.
hi @Gabriela A.Viggiano , yes that is possible. There are two approaches I would recommend here.
Let me know if this makes sense.
Hi @Gabriela A.Viggiano ,
welcome to the Atlassian community!
If the workflow is shared between multiple issue types, you can :
Hope this helps,
Fabio
Thanks for the advise. In the meantime I get the proper permissions to edit workflow for that issue type (it is restricted).
Now another question comes to my mind, what if the issue type is used in different projects, if I create a specific workflow for Incident type (p.e.) and add a post function to it, is that going to replicate in all projects that use incidents? Wonder if I can config the workflow for that issue type in that particular project only.
Hello @Gabriela A.Viggiano
Basically, every project has its own issue-type scheme. So, if your project issue type scheme has an incident issue type, it will be having its own workflow, screen, Field configurations, and all. And that will not be shared with any other project until you want to do that intentionally.
So, workflow configuration for that issue type is for that particular project only. It will not be reflected in other projects.
Hope this ans your questions. Let me know if any other queries.
