Is it possible to create new project in Jira through Rest APi in Postman?
CHINNAMUTHEVISAI.SATYANARAYANASHARMA
I'm learning Rest Api's in Jira now .
i want to know is it possible to create a project in Jira with Rest API.
i got a code through Chat Gpt and tried to do that but got some error .
in body i mention like this
  "key""ATP",
  "name""Akshith Test Project",
  "projectTypeKey""software",
  "lead": {
    "key" : "61f93c0fb3ec760068c11a32"
getting following error
  "Invalid request payload. Refer to the REST API documentation and try again."
i used post method to do this and i'm Jira admin i have a permission to create new project
Fabio Racobaldo _Catworkx_
Hi @CHINNAMUTHEVISAI.SATYANARAYANASHARMA ,
sure, you can. Please take a look to the following documentation https://developer.atlassian.com/cloud/jira/platform/rest/v3/api-group-projects/#api-rest-api-3-project-post
There are some missing parameters in your request.
Fabio
Thanks Fabio for your help.
even after mentioning all details i got error that error parsing Json , check your body is valid error.
i added this code in the Body
  "assigneeType""PROJECT_LEAD",
  "avatarId"10200,
  "categoryId"10120,
  "description""Cloud migration initiative",
  "issueSecurityScheme"10001,
  "key""EX",
  "leadAccountId""61f93c0fb3ec760068c11a32",
  "name""Example",
  "notificationScheme"10000,
  "permissionScheme"0,
  "projectTypeKey""business",
i want to remove avatar id from that as we dont user Avatars more .
can you help me ?
Taha El Majidi
Did you check if the user you are using has the permission to create projects ?
Hi Taha,
Yes User is an Org admin and he have a permission to create project.
Taha El Majidi
What's the error code you are getting ?
Hi Taha,
I'm able to create a project through Rest API
i used below code.
"key""SOF",
 "name""Software Sample",
 "projectTemplateKey""com.pyxis.greenhopper.jira:gh-scrum-template",
 "description""Example Project description",
 "avatarId""27370"
