Is it possible to have a same project name(ABC) if i delete an existing project with the name (ABC)
Shaikh Arif Mohd Mondal May 6, 2019
I have a project with the name(ABC) and key (ABC). I want to create a new project with some changes and move all the issues of that project to new project. I want to ask
  • If my old project is ABC with the key (ABC) and i create a new project with name (XYY) and key XYZ. and i move all the issues from ABC to XYZ, and delete ABC.
  • Can i rename XYZ to ABC after deleting and change the issue KEY from XYZ to ABC.
Aleksandr Zuevich
May 6, 2019
Hi @Shaikh Arif Mohd Mondal,
Yes, it all should be possible.
Is there anything i should be worried about if I move all the issues from one project to another?
