Is it possible to link issues via wf post function Script?
Harsh
August 10, 2023
Hi All,
I have 4 status in PROJECT 1-
Open -> In Progress -> In Review -> Resolved.
Step 1
I have a ticket in PROJECT 1; when the ticket is moved from Open -> In Progress; it automatically creates a ticket  in PROJECT 2 and links to PROJECT 1 ticket with link type 'has dependency'.
Step 2
Now, when the above created ticket in PROJECT 2 is cancelled, the PROJECT 1 ticket(which was in IN PROGRESS status) moves to IN REVIEW, which in turn creates another ticket in PROJECT 2(but with different summary, I am setting the summary and description via scripting).
My question: is it possible to link (type - 'is caused by') the ticket created in Project 2(Step 2: IN REVIEW transition) to the ticket in PROJECT 2 which was cancelled(created when IN PROGRESS status) before in Project 2(based on summary), via post function or JIRA automation.
I tried via automation but no luck. If this is possible can via scripting can some one help!
Thank you.
Nic Brough -Adaptavist-
August 10, 2023
Yep, if you have Scriptrunner, these are both possible.
The first is surprisingly easy if you have a recent version of SR (one with HAPI capabilities)
From memory:
// Create a new issue
def newIssue = Issues.create('projectKey', 'issueType') {
    setSummary('New issue')
// Link the new issue to the existing issue
issue.link('linkType', newIssue)
The second is a bit more involved, but you should be able to find snippets and examples to help you with it in https://library.adaptavist.com
Harsh
August 11, 2023
Hi @Nic Brough -Adaptavist-
For the first one I had already implemented the logic and it works perfectly, since it's a straight default post function (clone funtion in wf).
Since for step 2: the requirement, is to link the issue which is getting created when it goes to in review status to the ticket which was triggered in step 1 and is cancelled.
Thanks again for the help. Any suggestions would be a great help. I think it's a bit tricky.
Harsh
August 12, 2023
Thanks!
Fabio Racobaldo _Catworkx_
Harsh
August 11, 2023
Hi @Fabio Racobaldo _Catworkx_
Thanks for the reply. I did try but it works when you are creating a issue in one transition.
It is not working in my scenario. If you have any test script that fits the scenario would be a great help.
Thanks again!
