I have written two test cases using Jira with the Zephyr plug in. We can edit, but we cannot merge two of these test cases together. Is there a way to do this?
Hi t whitehouse,
Currently, there is no way to merge test issues using Zephyr for JIRA. I would suggest searching JIRA's Marketplace for a plugin that offers Issue Merging capabilities and giving that a try and see if it fits your needs.
Daniel
Hi All..
We had similar problems merging zephyr data from one instance to another. We finally created a parametrised job to copy all zephyr data to the new instance.
Check our blog for further details: https://kreuzwerker.ch/post/jira-merge-and-beyond
There you can find all the steps needed. You can try to perform it yourselves or we would love to support you.
Best regards
Tobias
