I often want to add my own content to the original UI.For example, when you click a comment, some comment templates will be added automatically.
I think this will help you, you'll need to create your own plugin with Forge. You cana lso look at the marketplace to find a suitable plugin.
Hi,It seems that Jira Cloud can no longer modify the UI through the Forge plug-in.
