Is it possible to reassign issue based Resolution field selection?
Bar T
Not sure how to Post Function this.
We want all resolution = defer to be assigned to a certain person. Is this possible to set in Jira Server?
Tuncay Senturk _Snapbytes_
Meg Holbrook
June 1, 2018
Hey Barbara, give this addon a try: Automation for JIRA
What you're asking for can be accomplished with the suite of automation tools provided, and it's relatively inexpensive (will depend on your user base though).
Steven F Behnke
June 1, 2018
This would typically be accomplished by developing an Event Listener that inspected issues as they were modified and if it encounters a Deferred issue, to modify the assignee field.
Bar T
Is an event listener an add on feature? Thanks Steven.
Nic Brough -Adaptavist-
June 16, 2018
Yes, you will need some code to implement a listener to do this.  There are several automation add-ons that could help you do it - Automation for Jira and ScriptRunner for example.
