×As a Jira user I can access Jira's own project and create issues, vote, watch, comment and so forth
Can I give my users the same access, or is this only possible because I have an active Jira license? I'm aware of Jira Helpdesk, I'm specifically asking for Jira Software
Hello @Daniel Everland
In order for your users to edit/write tickets on the Jira's own projects, for that they need to have an Atlassian account.
Are you sure this is enabled by default? I made a dummy account through the link you provided, and I can't make any action on behalf of it. If I comment, the comment is posted by "Anonymous", furthermore the watch and vote buttons are disabled.
If I click the 'Login' button in the bottom left, I'm forwarded to the following page
Could you elaborate? Steps to reproduce would be immensely helpful, my project is everlandgames.atlassian.net if that helps you any. Furthermore, I outlined what I've tried so far in Tarun's answer
On jira.atlassian.com there is a free sign up, so if you want your users to be able to vote or watch issues there, they can just sign up there.
To do this, they should have a link for sign up, there should be a link on the log-in page.
For your own instance it depends on your settings.
As site-admin, you can invite users or you enable self sign up on your site(that may lead to a lot of accounts and with that to high subscription cost)
https://confluence.atlassian.com/cloud/invite-edit-and-remove-users-744721624.html
https://confluence.atlassian.com/cloud/configure-site-access-744721636.html
