Good day
I am trying to set up a swimlane that would show all the clones of issues, but I am having no luck finding a way to search by link type or even to search if it is a clone.
Please any help would be great, I am trying to do this by JQL and not by Querying it.
Thanks for any help
The hasLinkType issue function from ScriptRunner will give you this; we are using jira on prem with the ScriptRunner add on. ScriptRunner is a must for Jira, it allows you to "code" in any quirks the teams want without buying more and more plugins.
issueFunction in hasLinkType("Cloners")
I got this info from here Jira JQL functions: The ultimate guide
project in (ETL) AND fixVersion = Q4_2019 and issueLinkType in (Cloners,clones,"is cloned by")
@Leena Bejoy , thanks for the tip. issueLinkType is not an available field in my advanced query options. Are you using a plugin? Are you on cloud or server?
@Christine Diamond Your jira is on cloud or on premise server?
Hello @Liam Maeder ,
unfortunately you'll need a plugin for this task.
Look at this answer for your options: https://community.atlassian.com/t5/Jira-questions/jira-query-issues-with-linked-issues/qaq-p/426769
With kind regards,
Mario
