Is it possible to see past and finished sprints in Jira?
Maria Luiza January 29, 2025
We would like to see past sprints but couldn't find it in "filters"
3 votes
Shalini Pradhan
January 29, 2025
Hello @Maria Luiza ,
Good day! :)
Please navigate to your project -> project settings -> Features and scroll down, you would see Report, enable ( toggle in on ).
Now you can navigate back to your project and on side bar, you would see Report option. From there you can select 'Sprint reports'
Thank you!
Thank you! It works :D
Like John Funk likes this
Shalini Pradhan
January 29, 2025
@Maria Luiza You are welcome :)
You can accept the answer if this helped you, so that it helps other users with the same concern.
Have a great day!
John Funk
Hi Maria,
If you are looking for JQL syntax try using:
sprint in (closedSprints(), openSprints()) AND project = ABC
Manne Kjærby - ProProces
Go to Reports in your project where the sprint is created.
Choose Sprint reports, here you are able to see all past sprints.
You can click on the *** and click view in issue navigator to see all issues attached to the sprint.
Sorry but where is "Reports"?
When we go start a sprint we just select "complete sprint"
Hope it makes sense :-)
Mine isn't like this :,)
FREE
