Is it possible to share jira issue with external email?
Eran Kaufman
we have subcontractor working with us, and I want to share with him the relevant bugs. I don't really need him to fully collaborate within jira, but just to have reference and relevant data from specific issues
Is it possible to share with him only his relevant issues, without allow him to access our project?
Chris Cooke Old Street Apps
Hi everyone,
Have you tried external share for Jira? It's useful because it offers a live view of Jira issues, without using up licenses, and makes it very easy to email issues to external users, while letting them comment and add attachments too!
Let me know if this helps!
https://marketplace.atlassian.com/apps/1220441/external-share-for-jira?hosting=cloud&tab=overview
Eran Kaufman
tnx. Nice add on, yet not free of charge :(
Thanks for your feedback Eran, all our apps are available for free to registered charities and non-profits if you work for one of those. :)
https://www.atlassian.com/software/views/community-license-request
We're also just releasing a lite version to get you started :)
There is the Lite, free version to share jira issues externally
Like Eran Kaufman likes this
Ignacio Pulgar
June 2, 2019
If using up a license is not a problem, I'd suggest this solution:
  1. Create a custom field of type User Picker (multiple users) and name it ie: Invited Users.
  2. Add that field to the permissions you'd like the external user to count with (ie: Browse Projects)
  3. Add the field to the project's screens.
  4. Edit the issues you'd like the external user to be able to see (and therefore, be able to be notified, as per the notification scheme settings) by setting that user into the Invited Users field.
After that, the external user will be abie to see and be notified of changes just of the issues you want.
Eran Kaufman
will the external user be able to see only these issues, and not the others, even within the same project?
what will happen if the external user tries to see other issues in that project?
Ignacio Pulgar
June 2, 2019
The external user would only be able to view those issues, and not any others in the project.
Should that user enter the URL of an existing issue where the Invited Users field lacked her username, a message would be shown instead of viewing the issue, stating:
"The issue you are trying to see does not exist or you do not have permissions to see it".
Eran Kaufman
ok, tnx for the assistance. will check with my colleagues if this solution answers their need
Joe Pitt
Not through JIRA directly. You can produce reports, download them, and send them to him. Unless you have information he isn't allowed to view the easiest solution is to give him only browse permission to the projects they need to see.  For users I have with similar requirements I have a project role called 'browse only' and assign them to that role. In the permission scheme that role only has browse permission.
