Is it possible to unwatch all issues in a jira project?
Mikael Juellund February 12, 2015
A colleague is no longer involved in a project but gets spammed everytime there is a update on a issue he is watching. In relation to this I wan't to know if there is a way to unwatch all issues at one time instead of unwatching every issue manually? Or is there another function that can stop updates?
Best regards
Mikael
Nic Brough -Adaptavist-
February 12, 2015
If your user has "bulk edit" permission (it's a global permission), then you can run a filter for "project = X" (or even "I am a watcher" or whatever else), bulk edit the results and remove yourself as a watcher from everything.
Amber Baldet
September 3, 2015
What if after leaving the team, the user is de-permissioned from bulk edits, or it's inappropriate to ask them to do this? Bulk unwatch should be an admin feature.
September 3, 2015
I wouldn't say quite that - I'd say bulk unwatch should *also* be available so an admin can perform it for someone if necessary. I'd raise that as an improvement at https://jira.atlassian.com/browse/jra
shivamdu July 20, 2018
Was this created. This feature is still not available right?
Like # people like this
