I would like a default sprint value when creating stories, negating the need for a user to select a sprint
What kind of default value would you like to set? Sprints are opened and closed. You can not set the same sprint value for all issues. Moreover usually issues are examined during planning and added to a sprint. It is a manual work to do.
