When we migrate projects from jira server to jira cloud using jira migration assistant, will it migrate the completed sprints also?
Hello @Kavitha K
We are having an issue when migrating software projects from cloud to server. The sprints are not been migrated. Did you have the same issue? Do you know how to fix it?
Thanks in advance.
Creating a sprint in the source instance. Having a open sprint in the source instance could fix the error. I tried and worked.
Best regards
Yes they will be. Please refer to What gets migrated with the Jira cloud migration assistant under the list What is migrated.
