Is there a simple way to generate a report for each Jira project that outlines its components?”
Lucas van Gelderen October 14, 2024
I want to see for each project which schemes it is making use of. In Jira I have to look up every different schema for a single project.
2 accepted
John Funk
Hi Lucas - Welcome to the Atlassian Community!
Just to clarify, when you say components, you don't mean the components field, but you mean the schemes/configurations. Is that correct?
If so, no, there is no simple way to do it. I suggest you try the Revyz Configuration Manager for Jira app to see if it gives you want you want.
Hi John,
Yes I mean the schemes/configurations. I shall take a look at the app Revyz Configuration Manager for Jira.
Like John Funk likes this
John Funk
Check out the Site insights option after you install the app and do backup.
Sarp Egemen
Hi @Lucas van Gelderen
I am not sure if I understand your problem correctly but can you check:
Project Settings > Summary
This would be the view you get:
HI Sarp.
Thank you for the answer. This is a summary for 1 project. I would like to see an overview for several projects at once, to which configurations/schemes the projects are sharing.
I know that as an administrator you can see this per scheme or configuration, but i am hoping for a report or app that makes this visible.
Like Sarp Egemen likes this
Sarp Egemen
Thanks for the clarification. I’m afraid I don’t know if it is possible in Jira natively. Your best option would be a third-party marketplace app, as Mr. John suggested.
