Is there a simple way to generate a report for each Jira project that outlines its components?”
I want to see for each project which schemes it is making use of. In Jira I have to look up every different schema for a single project.
Hi Lucas - Welcome to the Atlassian Community!
Just to clarify, when you say components, you don't mean the components field, but you mean the schemes/configurations. Is that correct?
If so, no, there is no simple way to do it. I suggest you try the Revyz Configuration Manager for Jira app to see if it gives you want you want.
Hi John,
Yes I mean the schemes/configurations. I shall take a look at the app Revyz Configuration Manager for Jira.
Hi @Lucas van Gelderen
I am not sure if I understand your problem correctly but can you check:
Project Settings > Summary
This would be the view you get:
HI Sarp.
Thank you for the answer. This is a summary for 1 project. I would like to see an overview for several projects at once, to which configurations/schemes the projects are sharing.
I know that as an administrator you can see this per scheme or configuration, but i am hoping for a report or app that makes this visible.
Thanks for the clarification. I’m afraid I don’t know if it is possible in Jira natively. Your best option would be a third-party marketplace app, as Mr. John suggested.
