Is there a way for me to rearrange the Versions in Backlogs?
Brian Santos
April 6, 2021
I know we can do this in Release Page, however, I have already re-arranged this and it doesn't reflect accordingly in the Backlogs page:
Versions on Release Page:
Versions on Backlogs Page:
I don't know if this has something to do with the Active Sprints, I did activate the Sprints under the V1_R4 Version first before I activated the ones that are in the other Versions.
Looking forward for the response! Thanks!
3 votes
Bill Sheboy
April 6, 2021
Hi @Brian Santos
When you navigate to the Releases view, the versions are displayed in release order, with the next release at the bottom of the list.  As you note you may drag-and-drop to change the order of release.  Changing the sort columns has no impact.  (Which is why you should navigate away from that page and back to it when you want to re-order releases.)
The view of versions on the backlog shows in release order, top to bottom.
Best regards,
Brian Santos
April 6, 2021
Got it @Bill Sheboy, and it worked. Thanks!
Like Bill Sheboy likes this
Scott Paden
Ohhh... Use the Releases dialog, not the versions dialog:
Thanks!
Dorian Simpson
January 27, 2024
Is there a way to order them in the Backlog view? Seems odd they are in a different order :( The time order for these is: Iteration1->2->4->Z, but they show up in the order created. Must be a way?  Thanks!
Daniel Swid August 26, 2024
Me too, this super frustrating
