Is there a way in JIRA to migrate users from a Delegated LDAP to a Connector LDAP User directory.
Ankuskum
We are using OPENLDAP and we have migrated all the users in delegated OpenLDAP.
Next step:
We want to move all the users in LDAP without loosing any data.
Andy Heinzer
July 2, 2018
It could be possible, but the trouble tends to be in regards to the groups that these users are members of.
So you could just add another user directory in jira, of type Connected LDAP, and then use the same credentials/settings as the previous directory.   This can then sync all those same user accounts into Jira.  If this directory is ordered on top, then users would be logged in via that user directory instead.
The problem usually comes in regards to how you have setup Application access in Jira and other permissions that can frequently be governed by group membership.  The most common problem with doing this kind of migration is that users can't login to Jira immediately after this change.
If all your current openldap users are belonging to groups that only come from this first delegated directory, then you will probably need to go back into Jira and make sure that these same groups in the new ldap are also getting synced into Jira and that each user has membership to those groups.
If you're not using the groups in ldap, but instead are utilizing the read-only with local groups option, then you might not need to do the above as the user accounts are getting memberships from groups that exist in the internal Jira user directory.
I would recommend setting up a staging server just to test out a change like this before doing it on a production instance.  This kind of change does have the potential to lock out all users in Jira, so test it first.   There is also some good information in regards to Migrating users between directories.
Ankuskum
Thank you for reply.
But i am having one doubt here.
How will sync jira password to the LDAP?
Andy Heinzer
July 4, 2018
Jira doesn't track what the user's password is for external directories.  Instead, Jira passes authentication directly to that directory.    If all your users were already in the delegated LDAP, you won't see a difference here in terms of username/passwords.
But if some or all of your users were just in the Jira Internal directory instead, then Jira could have a different password for that user than the LDAP is using.
