Is there a way or place to view an issue's notification history, hopefully exclusive of comments?
Phil Bustin
March 14, 2023
Is there a way or place to view an issue's notification history, hopefully exclusive of comments?  As an admin, I'd like to be able to verify notifications while notifications are turned off.
Yuliia_Borivets__SaaSJet_
Hi @Phil Bustin
Have you checked the audit log? Notification updates should be available there (Settings > System > Audit log).
It should capture the next events:
Notification scheme created, Notification scheme deleted, Notification scheme copied, Notification scheme updated, Notification added, Notification deleted, Notification scheme added to project, Notification scheme removed to project
Info from Audit log events in Jira
Phil Bustin
March 14, 2023
I'll try that.  I think it would be useful to users of all stripes to be able to have a section in statuses (if not transitions) showing a log of non-comment notifications (date/time/notification/recipients).
Phil Bustin
March 23, 2023
[Deleted reply]
