Is there a way to add a recurring reminder for a task? I would like to receive an email every working day for a specific task
You can create a filter which selects your task and then make a subscription for the filter. the Subscription means that a email will be sent to you or a group of users on schedule (you provide the schedule yourself).
Can you elaborate a bit on the schedule?
You can read more here. You need to create Personal Subscription if you are the only one who has to receive the email
https://confluence.atlassian.com/jira064/receiving-search-results-via-email-720416706.html
Hi Luda,
The schedule defines how often a filter you have subscribed to is run against all your issues and you get email notification if any issues match.
For example if you set it run ever hour then it will look for matching issues every hour and notify you via email if any issues are found.
