Is there a way to auto populate text in a comment screen that pops up on transition?
Eric Blumberg February 18, 2019
I have a transition that when executes, it prompts a blank comment screen to come up and force the user to leave a comment. Is there a way to Pre-populate comment screen with "Approved by {USER} ON {TIMESTAMP}" (ex: Approved By John Smith on 1/25/19 1:05PM
Patrick Cartier [Candylio]
February 18, 2019
You can definitely get this done with Automation for Jira using the trigger for when the issue is transitioned, edit issue function, and smart values.
Doesn't the issue history record the approver and time of approval if you use the approval function, though?  I might be wrong about this but it's what I remembered.
I should clarify, we are not using the service desk, I am just naming the transition approved.
Is there a way to achieve this with scriptrunner, or just within JIRA?
February 18, 2019
With Scriptrunner you could follow something from this post:
https://community.atlassian.com/t5/Jira-questions/Groovy-post-function-create-add-comment-with-custom-field-value/qaq-p/305477
Have a post function for that transition that adds the assignee and date.  Pretty sure you can add some text in there too.
Thanks for the fantastically quick reply.
I looked into the link, but I am not sure how I would get this configured in the cloud version of scriptrunner.
February 18, 2019
In the adaptavist library (you'll need to create a username) there's this code:
 https://library.adaptavist.com/entity/update-the-value-of-a-custom-field-in-jira
You could use similar code to this as a scripted post function.
Eric Blumberg February 25, 2019
This is not quite what I am looking for.
DO i need to go through all this still if I would settle for the same static text string on every comment?
February 25, 2019
This is what I was looking for. Thanks man!
Andrej Kováč March 14, 2024
Hello @Patrick Cartier [Candylio] , @Eric Blumberg ,
I am looking for exactly the same "hack" and unfortunately, the link provided is no longer valid. Could you by any chance remember and tell me how this is done?
Thanks!
