I need to use External System Import to create multiple custom fields. However, I do not want it to create an issue for every row in the CSV file. There are over 250 rows. I would rather just create the custom fields without creating the issues. Any help you can provide would be greatly appreciated. Thank you.
-Jeff
Hi @Jeffrey Rethford and welcome to the community!
External System Import is purely intended for importing issues with related data. I don't believe there is a way to bulk create custom fields.
Mark,
Thank you for your timely response. I really appreciate the feedback.
-Jeff
