We have a custom field called "actual hours spent" on an epic and wanted to see if that custom field can be added in the epic report graph. It does tell about the "story points" but we want to add this field to avoid the manual work.
Hello @Bharat Kalia
Which report specifically are you referencing?
Many of the built in reports are not customizable. A few reports offer a small number of options, such as choosing between story points and time fields for a burndown.
@Trudy Claspill There are two reports I am specifically interested in - EPIC report and Epic Burndown.. If possible I am looking to add a new line (Actual days spent) line in graph for epic report.
It is not possible to customize those reports in that manner.
You would need to look at using a third party app to generate similar reports.
Thank you @Trudy Claspill for the insight.
