When I use the search box from the top right of the screen my FILTER ISSUES BY LAST UPDATED defaults to "Any Time". There are other uses where it defaults to 30 days. Is there a way to control what it defaults to?
Yes, you can set a default for the "FILTER ISSUES BY LAST UPDATED" option in the search box. To do this, go to the "Advanced Search" page and scroll down to the "FILTER ISSUES BY LAST UPDATED" section. Here, you can select the default option that you want to use.
Thanks for the response. I am not able to reproduce the steps you provided. Can you include a screenshot?
I can't find that setting either - do you have any tips?
