Is there a way to disable CAPTCHA for a particular user in Jira?
Tim Crall
August 21, 2015
mrPsycho August 26, 2019
no answers from atlassian?
Dawid March 12, 2021
No answer
Mike Friedrich
August 21, 2015
all or none
If possible would that not be a security whole?
Tim Crall
August 21, 2015
I don't see why it would be a security hole for me as an administrator to designate one account to have captchas disabled. I am attempting to get authentication working for a service account to use the API, and having captchas turned on everytime my login attempts fail a few times is a pain because it means that any future attempts will definitely fail until I clear it.
darrenpegg
August 21, 2015
If using the API would the password be correct everytime?
Tim Crall
August 21, 2015
in theory, yes. I'm trying to configure a 3rd party application to connect to the API. Not really sure why I'm getting authentication errors, but the captcha is slowing my ability to debug the issue.
darrenpegg
August 21, 2015
ahh I see.. hmmm.. I would 1st maybe use a dev instance, what is the 3rd party app?
Tim Crall
August 24, 2015
Yeah, I probably should use a dev instance. I will try that today if my next attempt doesn't work. I'm trying to configure the new Hygieia Dashboard from Capital One.
Dawid May 8, 2019
We have same issue on our integration with JIRA using API - from time to time we get capcha validation for service account used for the integration altrough we always use valid user name and password.
Any solution for that?
I would see a possibility to add list of exception in JIRA where admins could add all system accounts to disable cptcha at all for them.
Rodri Alvarez April 22, 2019
Same problem here. Is there any way to disable this CATPCHA verification for all Service accounts used internally in Bamboo?
darrenpegg
August 21, 2015
I wouldn't say it is a security hole.. Plus you would turn it off if connected to Active Directory if it was being used for user management. So would depend on the use case.
But it is all or nothing if using JIRA to manage users
Adrian_Tan
June 10, 2020
I'm also looking at the possibility of disable for just some specific accounts.
For some weird reason, my API calls are getting 403 / 401s despite the fact that I'm using correct credentials.  The issue is actually very intermittent. A total failure happens when the CAPTCHA is triggered. Someone has to go to the admin page and reset login count.
It's a huge problem for us right now and I see that some are getting the same authentication failure issue.
Dmitry Shinelev March 12, 2021
Did you find any solution how to fix it? I am struggling with the same issue.
My research tells me that there is no flexible solution. Am I not right?
Nutanix_Jira-admin
May 25, 2021
Hi @Adrian_Tan / @Dmitry Shinelev ,
Any solution for this? I am not sure why is this happening for service accounts as these are used in scripts and password will be constant unless it is updated manually.
Did we found any root cause for this?
Dmitry Shinelev May 25, 2021
@Nutanix_Jira-adminunfortunately no, there is no way to disable CAPTCHA for a particular user in standalone Jira.
Remedy Partners July 26, 2018
having the same trouble. once every few months the captcha is triggered
bwalk
January 6, 2017
Tim, in your comment you mentioned that you were getting authentication errors and the captcha was being triggered for your service user.  Did you ever figure out why?  I am having the same problem (the password is correct for all requests).
