When I export Epic, Task, and sub-tasks as csv from jira then everything comes as a separate entity in different rows. I want to export epics, tasks, and sub-task in hierarchical order? to manage the work properly and get a clear view.
Welcome to the community!
Out of the box this may not be possible. You may want to use certain plugins such as eazybi, structure or biggannt that let's you visualize the hierarchy and then the exports keep the hierarchy.
Regards
Hi, @Fabian Lim for your prompt responses.
I will certainly give it a try if that is free to use, else need to check with the company if they can buy the subscription.
Best regards,
Prasoon
Could the Order By not be jerry-rigged to work? Running into similar issues w/ add-ons etc being blocked.
welcome to the community! Just to add to Fabian's list of Marketplace apps, this can be done with two clicks in the app that my team is working on, JXL for Jira.
JXL is a spreadsheet/table view for your issues that - among many other things - understands and visualises parent/child relationships between issues:
You can then export your issue list to e.g. CSV or Excel, and that export maintains the order of issues:
(This works for any number of issues.)
Hope this helps,
Hannes
Hi @Hannes Obweger - JXL for Jira for your prompt responses.
Best regards,
Prasoon
If you would be interested in an add-on to view your entire eipc hierarchy in a CSV format, you can try out our plugin
Agile Tools : Epic Tree & Time in Status
The app also provides sum up at each level for time estimates and story points.
(Disclaimer: I work on RVS, the vendor for this app)
