For the purpose of ease of reference for a metric measurement, I'd like to create a filter that would return the values that are reflected on a team's Velocity Chart ...
Team/Project, Sprint, Committed SP, Delivered Velocity, ... and ideally, the % difference
I don't see any identified fields / attributes in the advanced JQL, nor a way to calculate ... I could get total velocity per sprint, but I don't know where the committed # is coming from, or how it is calculated.
Thoughts / suggestions welcomed.
HI @Kathy Dahmen,
There is no way to build a filter on the calculated values, those values are calculated when the velocity chart is run. You may be able to use an add-on app like EasyBi to get what you are looking for, or you could build the filter to pull the issues for the sprint(s), export them to a csv file and use Excel to calculate the values and build charts from there.
-Scott
Thanks Scott for getting back to me so quickly ... thats what I was afraid of. :)
