Is there a way to find out which comment is for which transition?
zahra13rashidi June 10, 2023
hi,
there is a transition in my project's workflow that has a comment required screen.
I'm reading the comments list through JIRA rest api.
I want to know is there a way to find out which comment belongs to that transition in rest api results?
2 accepted
Nic Brough -Adaptavist-
June 10, 2023
The only way to do this is to read the history (which you can do from the REST API) and manually match up the record of a transition with the same time stamp as a comment.
Jira does not record where a comment came from (REST, transition, issue view, post-function, etc), but it does stamp comments with a date and time on them, so you can reliably assume that if a comment has "12:26.0047 on the 40th of Octember" on it, and the history says "status changed from in-progress to done at 12:26.0047 on the 40th of Octember" then the comment was made during the transition.
thanks!
Walter Buggenhout
Hi @zahra13rashidi and welcome to the Community!
There is no link between a transition and the comments, so I am afraid that will be difficult. Since the comment is required and added during the transition, both the transition event itself and the comment are logged with a timestamp against the same issue. So using the transition timestamp, you could see if you can find a comment logged within the same time range of a couple of seconds. That won't be 100% fail safe, I guess, but a potential workaround maybe.
Hope this helps!
as you said it won't be flawless but I guess this is the only way.
thank you for your help!
FREE
