Is there a way to report on Project Setting Details?
Sara Creenan (M&T)
April 29, 2020
Is it possible to query the project details under project settings for all projects? Also, can you add fields to this page to capture additional Project details?
Bill Sheboy
April 29, 2020
Hi @Sara Creenan (M&T)
Have you tried to use the REST API to query information, or use webhooks to push event changes about projects, issues, etc.?  Both produce JSON that you can parse.
Here is the REST API info:  https://developer.atlassian.com/cloud/jira/platform/rest/v3/
And here is the webhook info: https://developer.atlassian.com/cloud/jira/platform/webhooks/
Best regards,
John Funk
Hi Sara,
No, you cannot add any fields.
And you really can't use JQL to do a report either. Maybe Category and Project Lead but that's about it.
You might could extract some more info via the API though.
Sara Creenan (M&T)
April 29, 2020
Can you create fields in the backend to capture at the project level and then report on them via the API? I am trying to integrate with another system and need to add a unique identifier and some other data elements at the project level to sync the two systems
John Funk
Nope, pretty sure that can't be done either.
