Is there a way to run manual automation rules via API?
Benjamin Peikes
January 29, 2024
Pretty straight forward question. We currently have some automation rules which our users run via manual triggers. Is there a way via API to run a manual triggered automation rule? How about ones that take parameters?
Jehan Bhathena
Hi @Benjamin Peikes
You can use the "Incoming webhook" if you want to trigger an Automation via API
https://support.atlassian.com/cloud-automation/docs/jira-automation-triggers/
Benjamin Peikes
January 31, 2024
What if you want to run automation as a manual rule from a ticket, as well as from a webhook?
Jehan Bhathena
Jira automation wont work with 2 triggers in the same rule, you'll have to create 2 same rules, each with a different trigger.
