Is there a way to search for restricted issues in team-managed projects?
Jennifer Choban - HeroCoders
I need to find all the restricted issues in a team-managed project. I tested using "Level is not Empty", but no luck. Any suggestions greatly appreciated.
John Funk
Hi Jennifer,
I am not aware of Issue Security being available for Team-managed projects.
Christopher Skoropada _Appsvio_
Hi @Jennifer Choban - HeroCoders
Issue Security does not work with Team-managed projects. You can check Project access in the project settings / Internal access.
Erik Beltran October 21, 2022
I dont think there is a way to query from the UI. Hopefully someone can share some ideas.
As an alternative you can make an API call for these fields:
I removed some data but this is how the restriction looks like:
Thank you.
Erik Beltran October 24, 2022
I found the answer for the UI after reading the JQL documentation.
There are a few things to consider including the project setup.
JQL Issue level security
In my case the JQL was something like this:
project = "ABC" AND level is not EMPTY
You can throw more projects in the mix or different criteria.
Hope is a starting point.
I personally was looking to remove the restrictions and I was able to accomplish that with a bulk update after I identified the issues.
Best of luck and have fun!
Thanks, ^Erik
Hi Erik,
I tried that, but when I tested it on a team-manaed project, it didn't work (I restricted an issue and then ran the query. The restricted issue didn't show up. But restriction.Value might get me somewhere.
Thanks for your help.
Like Erik Beltran likes this
Josh Stewart
November 28, 2022
@Erik Beltran This worked for me in a team managed project to identify the issues that had restrictions.
Thank you
