Hi -
I have several sprints created but I can only see the total story points for the sprint that is started. Is it possible to see total story points for sprints that have not been started?
Thank you,
Tracy
Yes it is possible. If you go into the backlog view in Jira Cloud, even sprints that have not been started will still have an ellipsis box (...) just below the sprint name. In my case my sprint that isn't started yet is called 'Sample Sprint3'
If you click that button, it bring up this popup:
The Total on this page can then show you the total story points in that sprint right now.
I hope this helps.
Andy
Hi Team,
It is showing only the standard-issue type story points and not the sub-task issue type.
Can we see the total story point including the sub-task story point for the sprint?
Thanks.
Note that this only works if at least one issue in that sprint is assigned to someone. If all issues in the sprint are Unassigned, then the ellipsis for some reason is not present. One of the many quirks of Jira.
I tried to delete this comment but could only edit it
You need a person assigned to a ticket to get the ellipsis box (...)
Hi, I cannot see that ellipsis box (...) in our backlog even a person is assigned to a ticket
hi there, I also can not see that ellipsis box (...) in our backlog even though I've assigned all stories to some people. I'm on free plan, is this feature paid plan only?
