Is there a way to show subtask numbers on a card of the board map.
Manon Bourgeois
I'd like to display the subtask (child ticket) numbers on the card layout.
KAGITHALA BABU ANVESH
September 7, 2021
Hello @Manon Bourgeois ,
By using default features, it's not possible. but you can display sub-tasks names on card. as below.
You can configure this as --> Go to Board Settings --> Card Layout --> You can add "Sub-tasks" to Backlog and Active Sprints .
Backlog view as below,
Active Sprint View as below
In Jira Card layout , you can show the sub-task issue keys as above.
Second Story -> Summary
FSP-7, FSP-8, FSP-9 --> Sub-tasks
Story --> Image
Flagged --> as Blocker to notify on Sprint health gadget
1--> Story Point estimation.
FSP-2 --> Jira story Key
Avatar --> Assignee.
Anvesh
Manon Bourgeois
Thanks Anvesh,
I am confused....I don't see the option 'card layout' under the board setting menu.
Could it be an authorization (privilege) problem? I mean I might not have all the admin privileges.
Manon Bourgeois
Sorry Anvesh,
Ignore last reply.
So we have to add them manually.
September 7, 2021
Yes, The board admin can help you in this case.
Barry Smith January 13, 2022
Was this actually possibly, I can't see from Manon's last comments.  Is it possible to add the number of SubTasks to a Board's Cards, or not?
Manon Bourgeois
Yes you can.
You can add the subtask number(s) on a card through the Board setting menu with Card layout option:
Board display:
Backlog display:
you need the permission to administer your project.
I see the issue, I'm running a Team Managed Project, whereas the screenshots you've pasted are Company Managed and have additional options.
