Is there a way to use REGEX in jira expressions using ScriptRunner Jira Cloud?
Anzar
August 24, 2023
I am trying to add a regular expression in the scripted validator in Jira Cloud for the text field with an email address.
I tried with
issue.customfield_10000 =~”^([])$”
But it is failing.
The error is:
Jira expression failed to parse: line 1, column 24: ., ?., [, ?.[, (, *, /, %, +, -, <, <=, >, >=, ==, !=, &&, ||, ??, ?, ; or EOF expected, = encountered.
I can use the native way but it doesn't allow me to add a custom error message.
Anzar
September 11, 2023
I found the answer myself:
issue.customfield_10000.match('^([])$')!=null
This worked like a charm.
You can validate any regex against a custom field during a transition.
Ram Kumar Aravindakshan _Adaptavist_
Hi @Anzar
Could you provide a little bit more information on what you want the Regex to do and where are you setting the regex to do?
Thank you and Kind regards,
Ram
Anzar
August 25, 2023
I want the regex to validate if the email field has the correct value.
for example: ramkum@..
is an incorrect form of email.
ramkumar@gmail.com
is a valid email.
Anzar Khan
Alisa Zamaraeva
August 24, 2023
Hi @Anzar
I can't tell if the regular expression is valid or not, but the error tells you that you should use "==" operator, not "=" since you compare two values.
Best regards,
Alisa
Anzar
August 25, 2023
Hi Alisa,
I dont want to do an equal comparison, I want to compare a regular expression with a string.
