Is there way to turn "Create issue" in any place of backlog in a company-managed project?
DK July 18, 2022
How to turn on Create issue+  in any place of backlog in a company-managed project?
DK August 12, 2022
No clear answer how to turn "+ Add backlog item"
Chris Buzon
July 18, 2022
This functionality exists in the backlog of a board that has just one project in its query filter. If you have more than one project, then jira doesn't know which project you want to create the ticket in and so you don't get the option to add directly.
If you go to the general tab of the board settings, you should see only one project in the "projects in board" section at the bottom - the associated backlog should allow you to do this.
DK July 20, 2022
@Chris Buzon thx for reply!
So can we use this feature?
What do I need to do turn it on? Not clear from previous answer.=(
Chris Buzon
July 22, 2022
Yup, assuming your user has permissions for creating tickets, I believe so.   it's possible you would need the ability to manage sprints too, but I don't know for sure if that permission affects moving tickets in the backlog (because you can change the ticket ranking in the backlog).
Chris Buzon
July 22, 2022
To your other question, you don't do anything to turn it on - it's either on, or something about the project setup doesn't allow for it.  You can tell by going into the backlog of that same board you're showing here.
DK July 25, 2022
The user can add items to the backlog.
The user can't use this pop-up button to create a backlog anywhere they want.
So can you please add exact steps that needs to be setup to turn on create an items using this popup "Create issue +" ?
Chris Buzon
July 25, 2022
No, there isn't a simple set of steps for troubleshooting a single user not being able to do this.  The problem is possibly in your board settings, or the user permissions - neither of those are simple to diagnose here.
Also, I don't know what you mean by "Create a backlog anywhere they want" (unless you mean create an issue in the backlog).
You don't create backlogs, they exist in Scrum boards (always 1 backlog per board), or you can enable them on Kanban boards by moving an entire status into the board column that says "Drag a status here to enable" - but, your query filter (JQL that drives the board) is critical.   If the backlog 'sees' more than one project, you cannot use that feature.
In your screenshot, PEOPLE project, is that the board (and backlog) the user is having problems with?
DK August 20, 2022
Create an issue in the backlog using "+Create issue" for now this popup don't appear
DK August 20, 2022
Yes, the issue in PEOPLE Project
