Is work description missing from issue worklog event?
robert_brower April 28, 2025
The documentation here... https://developer.atlassian.com/platform/forge/events-reference/jira/#issue-worklog-events
... states that the interface for the issue worklog event is
interface Worklog {
issueId: string;
author?: User;
updateAuthor?: User;
created: string;
updated: string;
started: string;
timeSpent: string;
timeSpentSeconds: number;
interface User {
accountId: string;
Where is the work description? How can I get it?
Piyush Annadate _ACE Pune_
Hello @robert_brower ,
Welcome to the community !
With checks, there should be a parameter as below to have the description within the worklogs interface.
comment
  You may create a parallel post at Developer Community as well
Thanks Piyush. Can you please tell me what you mean by, "With checks, there should be a parameter as below to have the description within the worklogs interface."
What is meant by checks? Do I need to configure something in Jira, or in my manifest for the events?
My manifest snippet
- key: worklog-event
      function: worklog-event-func
      events:
        - avi:jira:created:worklog
        - avi:jira:updated:worklog
        - avi:jira:deleted:worklog
Apologies, checks as of 'my view of going thru the documentation and other details'.
Probably the description (a comment in work log) is missing from the interface. Kindly raise this at Developer Portal.
Like robert_brower likes this
Thanks. I thought this was the developer portal. I meant to say that the data I get from this event does not contain the work description. That is consistent with the docs. But why is the work description omitterd?
Developer Portal is a dedicated, and here you will have developer and other community members as well.
FREE
