Issue Clone Post Function doesn't work
Jerome December 6, 2018
I have always the same probleme with the Issue Clone Post Function. I tried to clone to the same project but I get the following error message:
"System error. Invalid post funtion 'Issue Clone Post Function' settings"
Have you already met and fixed this problem?
For information, we run JIRA v7.4.2.
Thank you
Tarun Sapra
Hello @Jerome
Which plugin are you using for cloning the issue?
Tahnk you for you return.
We are just using Zephyr but I don't think this post function comes from this plugin: I thought this function was a JIRA Standard.
Tarun Sapra
Maybe you can see the plugin name in the "Manage app/plugins" sections.
As Jira provides ability to clone an issue as part of issue operation and not part of the post-function
https://confluence.atlassian.com/adminjiraserver074/advanced-workflow-configuration-881683764.html
Thus, it seems you are using an plugin.
OK Tarun, you're right. This function comes from the AM Utils plugin.
Thank you for your return.
Tarun Sapra
May be then try contacting the plugin vendor
Jerome December 11, 2018
I opened a case from the vendor. You'll find the link just below to follow the topic:
https://jira.cprime.io/servicedesk/customer/portal/2/CADS-2878
Thanks for your support
