Issue Collector Error
Laura Franklin July 25, 2024
The issue collector on our Jira Work Management suddenly started throwing an error today. It was working as expected yesterday.
I can see the error message:
 Required fields not present or fields too long in collector
When I look at the error in the console, it says:
{"errorMessages":[],"errors":{"customfield_11789":"Goals field is not editable"}}
The Goals field isn't used in our project anywhere. It is not a required field, but it is a locked field. It seems to be affiliated with a Jira Software feature, not Jira Work Management.
How can I fix this and get the issue collector working again?
Anandhi Arumugam _Cprime_
Hi @Laura Franklin Do you have any reference tot he Goals field in your screens or the issue collector?
Laura Franklin July 26, 2024
No. It isn't anywhere in our project or in the issue collector.
Are you able to create issues in this project otherwise? Can you please check the Field Configuration? May be someone made it mandatory there?
I am able to create issues directly in the Jira project. So it doesn’t appear to be from our configuration. The custom field is not marked as required, but is marked as locked.
This project is almost entirely based on issues being reported via the issue collector, which has made this a significant issue for us.
Vincent GUFFON July 29, 2024
Hi Laura, did you find a solution ?
Can you share a screenshot of the Issue collector? Is this custom code?
What screen do you want ? the form screen on the website or the configuration screen ?
It's a custom trigger system
The Issue collector configuration on Jira. This would help to see the customised issue collector and if any issues with that
Vincent GUFFON July 31, 2024
It's working now. Jira Update maybe ?
Laura Franklin August 1, 2024
It is working for me now, too! It must have been an update.
Good to know it is working now.
Same problem here !
