Issue Creation with a script/post function on a specific transition
DEJU ALIN MADALIN June 10, 2021
Do you know if can be possible to be created automatically an issue (for example a Story) when Epic issue-type goes through "Analyzed" status with a script/post function?
It is needed to be implemented this on Jira Server.
Thank you !
Best regards,
Alin
Payne
June 10, 2021
It is possible with ScriptRunner (I see you included the Script tag in your post so you may have that app?). If so, I can share a bit about how I accomplish this.
Yes, we have installed Adaptavist ScriptRunner for JIRA, installed version: 6.15.0.
It would be great if you can provide me some steps.
Thank you !
Best regards,
Alin
Payne
June 10, 2021
So, there is a lot of extra code in my script, but here is the section where I actually create a new issue. Some imports are necessary. Check it out and let me know if you have any questions about it.
IssueService issueService = ComponentAccessor.getIssueService()
IssueInputParameters issueIP = issueService.newIssueInputParameters()
issueIP.setProjectId(projectId)
issueIP.setIssueTypeId((String)issueTypeWorkOrder)
issueIP.setSummary(summary)
issueIP.setDescription(description)
issueIP.setReporterId(parentIssue.getReporter().getUsername())
issueIP.setDueDate(dueDate)
issueIP.addCustomFieldValue(customFieldRequestType,(String)(requestTypeMap[parentRequestType]))
issueIP.addCustomFieldValue(customFieldDisableAccess,disableAccessDate)
issueIP.addCustomFieldValue(customFieldRequestedFor,parentRequestedFor)
issueIP.addCustomFieldValue(customFieldApprovers,approver,backupApprover)
issueIP.addCustomFieldValue(requestTypeDescFieldId,requestTypeDescValue)
IssueService.CreateValidationResult newIssue
newIssue = issueService.validateCreate(jiraAdminUser, issueIP);
IssueService.IssueResult iResult = issueService.create(jiraAdminUser, newIssue);
DEJU ALIN MADALIN June 15, 2021
Now it's working to create a Story automatically when the Epic goes to "Analyzed".
But the wrong part is that it always creates a Story when the transition is accessed(because it's a shared transition).
Basically I need to be created only one "Story" on this shared transition.
Thank you !
