Issue Disabling Projects and Goals Features
Andrew Krystowiak
June 18, 2025
Is anyone else having issues removing user access to the Projects and/or Goals features? We do not use either of these features, but whenever I try to remove user access to one or both of these, it also removes user access to Confluence and/or Jira. Is this happening to anyone else? Are the Projects and Goals features required to use Confluence and Jira?
Mohanraj Thangamuthu
June 18, 2025
Hello, Good day. Have you tried disabling Goals from project settings >> Features >> Goals?
Andrew Krystowiak
June 20, 2025
Thanks for the response! Is your suggestion to disable these features at the individual project level? My main issue is that when I add users to the Jira Software through the User Management panel, Jira automatically enables Goals and Projects, and when I got back into the new user's account to disable those specific features, all Jira/Confluence access is removed. Does this make sense?
Like John Funk likes this
June 24, 2025
Hello, Thanks. Please go to Settings >> Apps >> Manage apps >> Select "System" installed apps. You will find "Atlassian Home for Jira Cloud" there you can disable the goals for whole site. Thanks
